"Hello Chris",
I am VERY Confident that what topquark very kindly Helped Me to Work Out regarding the Wiring of the Horstmann DRT2 Programmable Room Thermostat to My Home`s Heating System - which is presently without Zone Valves - is a correct method of achieving Temperature Control of the Boiler Firing and will eliminate Me having to run the Heating with only the Boiler Thermostat [Cycling On & Off !] to turn On & Off the Boiler.
Because I have remembered that the position where the cable from the Programmable Thermostat needs to exit the Floor is adjacent to a Washing Machine which I am going to need someone to move for Me [Back Problem] - I have Not done the Wiring as Yet - I have come to this section of the Forum to see If You had Replied with any Comments a couple of times in the last 2 Days.
Perhaps You have not had Time to read My Reply to You ?
Chris
Chris
