I did a VLF and IR test on my 33kv cable and IR resulted between 80 to 100Mega Ohms | on ElectriciansForums
Discuss I did a VLF and IR test on my 33kv cable and IR resulted between 80 to 100Mega Ohms in the Electrical Engineering Chat area at ElectriciansForums.net
Kenya
I did a VLF and IR test on my 33kv cable and IR resulted between 80 to 100Mega Ohms on all the phases and VLF between 0.270 to 0.470mA is the cable ok
Reply to I did a VLF and IR test on my 33kv cable and IR resulted between 80 to 100Mega Ohms in the Electrical Engineering Chat area at ElectriciansForums.net
Induced voltage can be a bit of a red herring when using DVM my guess is somethings moist.
T
The instructions tell you to test the insulation and you already know from the result of the previous test that the L and N are not insulated from...
davesparks
