P
Piratepete
Hoping to get sensible suggestions for this.
Family in semi-detached house are getting 'tingles' from the basin taps in their bathroom. They're the sensible sort so I have no reason to doubt them. Hubby is technical. He says they've only noticed it recently. But it also happens with the consumer unit turned off!
I've been in and could find nothing wrong. Did bonding tests on pipework and the bath (metal), insulation tests at the CU. All seems fine. Western Power guys had a look, changed the cutout (old one probably 60 years old). The floor is lino (very high IR to earth)
This is an extract of their latest email about the problem.
>'Update on the bathroom problem:
With regard to the odd bathroom problem; it still happens, intermittently, and is definitely apparent when in the bath - despite your measurements showing decent continuity between the two. I can’t explain it, but it is definitely not in my head!! Via a cheapo multimeter I think I’ve ascertained the following...
Is it worth adding some additional bonding between the bath an the pipework, or at least retesting the impedance between the two? I don’t want to worry about nothing, but with a small child and pregnant wife it’s bugging me still.'<
So guys, what should I do next. Nothing rude please!
- It measures about 1.5V AC between bath water or wet floor and taps/radiator
- If measured on DC setting, it shows about 0.8V with positive polarity on the water end
- It is present even if our consumer unit is isolated from the supply
- The duty cycle setting on the meter shows 50Hz
