Im getting new carpets fitted throughout the my flat and I had a couple of floor boards that are warped, so I decided to change them. I started to take up the floor boards on the landing of the hallway. I noticed 3 30A junction boxes feeding the ring consisting of 6 double sockets and 1 spur. 2 of the junction boxes have 2 red wires, 2 black wires and 2 earth wires each with no earth sleeving. The third junction box has 7 cables feeding it and all earth conductors are twist together with no sleeving.
I then decided to add earth sleeving to all bare earthing conductors but before undergoing the work I isolated the supply before commencing any work. Firstly I tuned off all electrical appliances connected to the ring. Turned off all circuit breakers at CU and turned off the main switch. As I dont have any testing equipment nor do I have any testing experience and the relevant qualification to carry out such a test. I then proceeded to open and close all lighting switches and socket outlets using a small electrical appliance to make sure no circuit was energised.
I then proceeded to disconnect the first 2 junction boxes that house 6 cables each and successfuly sleeved the earthing conductors. I then proceeded to the third as I started to untwist the earth conductors I got an electric shock. I went to the CU to double check the main switch and circuit breakers were off and they were.
Cant understand how I got a belt, puzzled! Can anyone explain what ive done wrong?
I got a new CU fitted just over a year ago with a electrical installation certificate, schedule of inspection and schedule of test results.
Thanks Wams
Thanks Wams
