I have a DC-INT (DC interference) fault | on ElectriciansForums
Discuss I have a DC-INT (DC interference) fault in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
andrevans
20 Steenbras Street, Gansbaai, Western Cape
I have a recurring DC Interference fault on my solar system. I have gone through all the scenarios recommended by Solis, but still no solution. All I can pinpoint is that the fault occurs when the batteries have just equalised at 100% and there is an additional power demand such as switching on a kettle or washing machine. Any advice as to what I can look for? The inverter was swapped out by Solis last year but still no result. MY system is as follows:
17 JA solar 535W panels in 2 strings
Solis S5 EH1P-6K Inverter
2x Hubble AM-2 batteries (5.5Kwh each)
Reply to I have a DC-INT (DC interference) fault in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
If the batteries are charged and the house is taking little then the full production of the panels will be dumped into the grid. As you have set...
Dangerous as well. If an earth fault occurred, such as you making contact with live mains, the RCD should disconnect the power in a sufficiently...
Greetings, I have a 5kwh solis hybrid inverter (S5-EH1P5K-L) with 12 (390W) JA solar panels . I was wondering if there's any requirement to...
What you're trying to do here is break the first and second laws of thermodynamics which, of course, is impossible. There are always losses in a...
    • Optimistic
