I need a 25mm plain to 20mm screwed conduit adapter. | on ElectriciansForums
Discuss I need a 25mm plain to 20mm screwed conduit adapter. in the Australia area at ElectriciansForums.net
Gold Coast
Have an isolator switch with 20mm screwed entries into the bottom. Have existing 25mm conduit I want to run into it. Ideally I need a simple adapter, 25mm plain to 20mm screwed conduit adapter. Does this exist cause I can't google one anywhere.
Drill out the 20mm threaded hole to 25….. ?
Is it 25mm pipe for a reason? Size and number of cables maybe?
You might find the hole in 20mm adaptor or bush is too small to accommodate.
Unless there was a good reason for not doing so, I'd also be inclined to enlarge the hole. No point in unnecessarily reducing down from larger size and losing additional capacity which may be helpful in the future.
Unfortunately I don't have a 25mm tap to reinstate the thread.
I'm changing over an external aircon to a pool pump so the 25mm pipe and 4mm2 is already there. But it was wired straight in and now the air con is gone I'm putting an isolator in for the future pool pump.
Have checked the opening and theres enough space for the cable and to drop a future earth in to the pool earth grid.
You don't say galv or PVC..for galv a 25mm coupler with a 25/20 reducer and a 20mm nipple would do it, for PVC glueing a 20mm male adaptor into a 25mm coupler would probably work.
25mm coupler glued over the 20mm plain/threaded works. It also is a super tight friction fit but obviously not waterproof.
Reply to I need a 25mm plain to 20mm screwed conduit adapter. in the Australia area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
