I need a compact armoured termination solution! | Page 2 | on ElectriciansForums
Discuss I need a compact armoured termination solution! in the UK Electrical Forum area at ElectriciansForums.net
T
Tidy Max
Good evening Gentleman.
I have had a small job in the pipeline for a while for a customer who is having stainless steel bollard lighting down either side of their drive way.
Nipped up to check on the jobs progress to find the client couldn't find the correct size light fitting so he has modified some. This has left me with a baked bean can sized space to terminate 2 armoureds...... any ideas would be very much appreciated.
I was originally going to terminate into a metal conduit Y split but unfortunately this will no longer fit!
Max
Reply to I need a compact armoured termination solution! in the UK Electrical Forum area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
