I need a professional opinion on a recent rewire please | Page 3 | on ElectriciansForums
Discuss I need a professional opinion on a recent rewire please in the UK Electrical Forum area at ElectriciansForums.net
chris140
Liverpool
Hi, I have just had a full rewire done on my house by a Napit registered company whom I didn't realise at the time where allowing none registered persons to do the work. I have had to call them back several times to many issues I came across and am now concerned about the safety of the rewire. I have a couple of pictures that they say are not a problem, but I am just not sure!
I would really appreciate it if somebody would have a quick look at the pictures and tell me if they look to be ok?
The first picture is showing the cables twisted around each other under the floor boards (they were also the same in the walls), the other pictures are of six cables going into a dimmer and a double switch that are next to each other, the dimmer is for the bathroom light and the double switch is for the loft light and inline extractor fan in the loft. The final picture is of a dimmer in the kitchen.
Thank you
  • [ElectriciansForums.net] I need a professional opinion on a recent rewire please
It’s immaterial whether it was cheapest or most expensive. A certain level of workmanship should be expected regardless of price.
ive known cheap to be fantastic and expensive be carp.
Yeah but if they are much cheaper then its going to be dog rough and use a cheap contactum consumer unit with no spd.. For those of us doing a decent job at a fair price we lose work to these cowboys and then customers wonder why the job is done so badly...
In one photo the cpc are connected another they are not and in one photo neutrals are inside back box and another they are in the wall
I think the sparky had been back to sort some of the issues between the photos being taken.
If the action of moving a switch plate a few inches from the wall causes problems then I would say it confirms that there is a problem with the workmanship.
Comical really
Coming back to connect a CPC to a metal faceplate is remedying a dangerous situation not fixing an issue
Like you say , you should be able to pull a switch or socket out from a wall without creating a hazard
Out of interest, what don't you like about Contactum CU's? I've never used one you see.
I wondered the same. I maintain lots of large sites, one of them has over 30 Contactum CU's ranging from a 4 way to TP 24 way. They've never upset me!
Totally disagree With the cheaper then it’s going to be dog rough.
Actually rate contactum boards. All the prewired links are shaped so you can get a nice neat finish and the colour coded breakers aren't a bad idea
Looking at the consumer unit, personally I would have put the upstairs sockets and upstairs lights on different rcds. (Same with ground floor)
That way, if an RCD trips, your not left without any lights in one room… between ceiling lights and plug in lamps.
unless your bedrooms are on the ground floor and living room upstairs
Was there any mention by the electricians of an SPD?
Hi, thanks for your reply. nothing they have done is right!
No there was no mention of an SPD
Hi, could I just ask, is the contactum board a cheap board? He had just replaced my good wylex one with the contactum one, said they were better. Also just to say I actually paid this person ÂŁ3300 and my house is only a very small 2 bedroom!
Oh no sorry, the ÂŁ3300 was for a rewire
rhat's an average figure for a 3 bed house without filling chases.. about right if nobfrills like cat5 everwhere, holding up the walls.nothing wrong with Contactum boards. middle of the range. good value for the price.
Reply to I need a professional opinion on a recent rewire please in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
looks like the OP has disappeared which is a shame, would be nice to get to the bottom of this.
