i need help!! | on ElectriciansForums
Discuss i need help!! in the Australia area at ElectriciansForums.net
A
alaa
hi
I'm not an electrical
I bought 3 phase wind generator ......output 24 vdc and 10A.
How to Connect the generator to a car battery to charging it ......... the battery have positive pole and negative pole ... and the electricity generator with 3 wires!!
  • [ElectriciansForums.net] i need help!!
What do you mean by a 3 phase Generator with a 24V dc output?
Anyway a Car battery is 12 V not 24V. You would also need a charge controller to stop you cooking the batteries.
Is this a 'wind' up then:D
Why would you pay $700 dollars to charge your car battery - just buy a new battery every time your existing one runs down - you still won't spend $700 by the time you're scrapping the car:)
Reply to i need help!! in the Australia area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
