I / R Testing on rcd socket | on ElectriciansForums
Discuss I / R Testing on rcd socket in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
c.boy
Scotland
Hi all,
Got my approved test tom its a scotttish thing!! Quick ? one of the socket circuits in the industrial test has an rcd socket on it. Am i best to disconnect this or would it be fine leaving it on???
Thanks my brain is in melt down!!! an 8 hour exam on a fri!!!!!:(
All loads disconneted so IMO I would remove it for the test or combine live and neutral on one clip and earth on the other for that circuit.
Chris
Chris
better to be safe than sorry!! ill just disconnect and block it.just trying to save a bit time!!
thanks
Reply to I / R Testing on rcd socket in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
