I worked out what a neon screwdriver is for | Page 3 | on ElectriciansForums
Discuss I worked out what a neon screwdriver is for in the UK Electrical Forum area at ElectriciansForums.net
Steve_P
Contrary to popular belief they are not fishing weights, neither are they a substitute padlock for the garden shed. No. A neon screwdriver is designed to be the perfect size to remove layers of paint from slotted screws so they can be removed with little or no swearing.
when i work out how to post pics, ill show you all my test kit--------
ok done it
my multi meter with a 500 volt insulation test built in btw
[ElectriciansForums.net] I worked out what a neon screwdriver is for
my amprobe very accurate, it has a slot at the rear of the case to attach it to your belt really cooll!, you look the part
my voltage tester
all that fluke craps cack (imo)
The water had seeped into the device and shorted out the resistor.a neon screwdriver tells you if there is a voltage realtive to your body .In theory they shouldn't work if you're up a wooden ladder with rubber shoes.
For the small amount of current required to run a neon, I suspect that the capacitive coupling between your body and the ground is sufficient.
Reply to I worked out what a neon screwdriver is for in the UK Electrical Forum area at ElectriciansForums.net
