Ice cream machine socket rewire Help! | on ElectriciansForums
Discuss Ice cream machine socket rewire Help! in the UK Electrical Forum area at ElectriciansForums.net
Skinnyramerez
Hi all,
I was wondering if someone with a lot more experience than me could help me out please.
I need to change a standard 2 plug 13amp socket to a 20amp supply with either a slow acting fuse or d-rated breaker to supply a 3 pin 16 amp female socket.
This is to supply an ice cream
Machine.
Whipped ice cream: Lunamil soft ice cream machines & milk shake machines
Thanks in advance for your time and patience.
All the best
Skinny
all depends on whatever else is on the same circuit. generally a 16A socket would be wired on it's own dedicated radial circuit.
Other outlets could be on the same circuit as this one so downgrading could present a problem. Do as Tel suggests, run in a dedicated circuit for this bit of kit and leave the rest of it alone
The installation, consumer unit, cable run etc are all unknown quantities to us, although we could second guess what is needed it would be best to get an electrician to check it out, no offense meant when i say your questioning is evident that its not a job for yourself, get an electrician on site to either instruct you or to do the job, too many variants means some answers you get could be misguided, i feel you wanted to initially change a 230v twin socket into a 3ph 16amp outlet means you are well out of your depths, it may be the case your installation dosn't have 3ph... hope you aint bought it yet????
Right so as it's needing a 3p supply your idea of connecting it to a single phase RFC is a none starter mate isn't it:)
You're going to need that dedicated circuit and if the design stage says 4mm then 4mm it is
Reply to Ice cream machine socket rewire Help! in the UK Electrical Forum area at ElectriciansForums.net
