a cone cutter, but stepped at various diameters.Step drill??
Be kind I’ve led a sheltered life
Discuss Ideally I need some 2G white surface boxes in PVC with 20mm knockouts in the Electrical Tools and Products area at ElectriciansForums.net
Oh right yeah I’ve a cone cutter.a cone cutter, but stepped at various diameters.
I have cone cutters and step also. If I want a 20mm hole though I'd use a 20mm holesaw - don't see the point of stepping up to 20mm.Oh right yeah I’ve a cone cutter.
I use it to make say 20mm holes a bit larger say to 25mm etc
Step drill! God you oldies crack me up
What's wrong with calling it a step drill? a cone cutter is different from a stepped hole cutter / drill whatever.Oh right yeah I’ve a cone cutter.
Reply to Ideally I need some 2G white surface boxes in PVC with 20mm knockouts in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
