Identification of AC side of LED driver please | on ElectriciansForums
Discuss Identification of AC side of LED driver please in the Lighting Forum area at ElectriciansForums.net
Darlington
I have a replacement LED driver for a lighting circuit that had normal halogen G4 bulbs. The forum has already put me onto the right track by explaining that the LED do not draw enough current to allow the original transformer to operate, so thank you for that.
However, my problem is I have removed the board from the casing and now cannot work out which side is the AC inlet and which side is the DC output. (Sarky comments accepted as what a pillock).
[ElectriciansForums.net] Identification of AC side of LED driver please[ElectriciansForums.net] Identification of AC side of LED driver please
Any guidance would be very much appreciated please?
Woodersd
Well that was a daft thing to do....
is there no markings on the board as to what is in and out? On the bottom?
maybe someone else can confirm, but would the black component with the yellow tape be some form of transformer, being the first component from the 230v side?
I wouldn’t want to test that theory myself
A photo of the top of the board only doesn't really help, as the components could be wired in any order, but a photo of the PCB tracking underneath might.
Judging by that big orange safety-rated capacitor on the right, I would say the top-right connector is the input.
However, I would want to be more certain before applying power. Maybe get the device number from the IC and the opto isolator. The data sheets for these will probably give the answer for definite.
Agreed, the end with the yellow capacitor is the AC input, i.e. the board is rotated 180° relative to the cover in the first pic.
There are various clues. The transformer, C5 and U2 are the three components that straddle the isolation barrier which therefore lies almost straight across the board. U2's LED (pins 1 & 2) must face the output side and its phototransistor towards the input. The main IC, the MOV and the MKP capacitor must be on the input side. The 220μF 35V electrolytic is the output smoother, etc.
It is indeed the transformer, however in a typical SMPSU it is electrically nearer the output, especially in a larger unit with power factor correction. The incoming AC is filtered (to keep the noise in), rectified, boosted by the PFC converter and smoothed to give the DC bus voltage. This is chopped at high frequency and fed into the transformer primary. On the secondary side of the transformer it merely needs to be rectified and smoothed to provide the output DC.
In a tiny unit like this or a wall wart, all the control electronics are on the primary side. All they require from the secondary side is the voltage feedback via the opto-isolator.
No beard (never had one), no Sodastream (had one in the 90s), significant interest in certain spirits (not the ghostly kind).
Perfect. Thank you so much.
Reply to Identification of AC side of LED driver please in the Lighting Forum area at ElectriciansForums.net
Thank you for getting in touch! Looking forward to use your services in the future! :)
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
