G
Gerry
Table 11a (osg) lists all the colour configurations for all standard cable types, this is straight forward. My question is :- When using 6243Y (flat three core & earth, Brown, Black, Grey & bare CPC). Which core would you sleeve as the switch wire and which one as the neutral when your using one core as a feed, one as a switch wire and one as a neutral. Seems a simple question but the only thing I can find is App 11.4 and this only relates to using the cable as an intermediate or as a two way. My tradesman says the grey should be marked as neutral (blue sleeving) and black (brown sleeving) for the switch wire. Does anyone know the specific regulation covering this or is it a case of common practice.
