Identify this wire from 1960 semi-detached house | Page 4 | on ElectriciansForums
Discuss Identify this wire from 1960 semi-detached house in the UK Electrical Forum area at ElectriciansForums.net
North Wales
Hi All,
Just brought a 1960 semi-detached house, and the front bedroom has this wire running along the wall.
[ElectriciansForums.net] Identify this wire from 1960 semi-detached house
Does anybody know what it could be?
Electrics are still original 1960.
I always find you got to be careful with the ginger, too much and it can be overpowering? I assume you mean root ginger, in the paste? I love a nice lamb curry, neck fillet is best I reckon.
Do you think we will ever find out about this cable?
Yep and not out of a jar. Root ginger & garlic mashed to a pulp, add a particular spice to a curry :cool:
Hi All,
Hand held switch used while in bed. In the fifties bedrooms it was common for a hand held switch to be dangling from a ceiling rose above the bed, so one could operate the ceiling light without getting up.
Reply to Identify this wire from 1960 semi-detached house in the UK Electrical Forum area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
I have to agree with littlespark stating that the wires should be absolutely cut loose at the fuse or breaker to make it safe. The heaters should...
