Identifying a PME system | Page 2 | on ElectriciansForums
Discuss Identifying a PME system in the UK Electrical Forum area at ElectriciansForums.net
K
Ken77
This may seem like a daft question but when looking to establish whether or not a supply is a TNC-S supply (PME) can you assume that where you have a new service head which has the link to for earthing conductor by incoming neutral that this is a PME supply?
Can you get a case where although you have new cable feeding the new service head it is still a TNS system with no earth supplied by the network?
I have asked the DNO to confirm what the supply is however they claim they do not keep any records of this, and need to send an engineer around to look at it. How would one tell?
The question was "How do you tell if PME?" - not TNC-S or TNS.
Look for label ?
I think it would still be wise to take a couple of loop measurements, as Tel has stated earlier.
Labels count for little as we have come across the standard domestic 'plastic' service heads used for both TN and TT systems.
We had one with a label on it and the 16mm2 PE had been pushed into the side hole without any connection. It gave use a Ze of 5 Ohms before we realized and gave it a pull.
Reply to Identifying a PME system in the UK Electrical Forum area at ElectriciansForums.net
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
Recommended Sponsor News
Hi everyone,
