IEC 62548 Final Draft
I am, sure this will be of interest. This is apparently the final draft of this document circulated for consultation before adoption and publication. Stuff on earthing is quite interesting. Hopefully, the DTI 3rd edition will align with this to ensure no anomolies. Just hope it has attached OK
I just realised I hadn't given the title of this document and so may of hidden its significance. It is called Design Requirements for Photovoltaic (PV) Arrays. This is a BSI document. Should have put it in the thread title but cannot now edit this. Apologies for this oversight.
sir,
thanks a lot for the info. can we have to link to download the document pls. it will be of much help to us. as i am personally working on solar pv array projects accounting to hundreds of MWs.
This thread was started in 2011 when the regulation was in draft so I guess the full release version would be of more value to you and will have been available for several years already.
