IEC C20 lead | on ElectriciansForums
Discuss IEC C20 lead in the UK Electrical Forum area at ElectriciansForums.net
High Tower
Nearly Esteemed
Birmingham
So........ We have just fitted out a comms room for a IT software client. having fitted the comms cab commando's and supplied the plugs to match, the company have asked us to supply the leads and fit the plugs.
However after a cursory glance at the back of the UPS units it would seem that the units are equipped with female C19 sockets, that would mean that these units would require a male C20 plug and lead which is far from ideal.
Anyone have any experience of this?
Are you sure that the C19 sockets are inlets? If so, it's worth querying this with the manufacturer of the equipment. I would expect these C20 fixed plugs for a power inlet:
4798.9000 | Schurter C20 Panel Mount IEC Connector Plug, Rated At 16A, 250 V ac | Schurter
It's not just non-ideal, it's wrong. If the manufacturer intends a male C20 cable to be used for the supply, I'd remove the UPSs and send them back. I think there's a mistake somewhere but let's see pictures!
As Lucien says, let's see some pictures of this one! It's either a misunderstanding, or it's been built on a Friday afternoon and someone has fitted the wrong sockets :) Daz
Reply to IEC C20 lead in the UK Electrical Forum area at ElectriciansForums.net
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even...
It sounds like the company involved in the works doesn't have the necessary expertise to undertake the task A company that specialises in this...
