If you didn’t have shears how would ? | on ElectriciansForums
Discuss If you didn’t have shears how would ? in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
V.Nearly Esteemed
Surrey
Cut meter tails and other thick cables
Junior hacksaw
Or
Nibble with side cutters until all the way through
When the shears or ratchet cutters were awol I have resorted to Hacksaw, angle grinder or even jigsaw in the past.
I'm one of those weird people who still uses a jigsaw for some trunking work.
Other than the horrendous noise, what's the problem with using a jigsaw on trunking? Tool for the job in many circumstances?
That's even worse!! I own a multitool, bit it's one of those bits of kit that are definitely in the 'emergency, nothing else can do it' category! Very very useful, occasionly! I hate the racket so much I try not to use it!
Been on jobs where they don't stop all day, sends me nuts!
Yep! Ummmmmmmmm yep! Agian? And agian untill I enter 5 words when one would’ve been sufficient to convey what I wanted to reply :oops:
Reply to If you didn’t have shears how would ? in the UK Electrical Forum area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
