I'm after something, but not quite sure what it is! | on ElectriciansForums
Discuss I'm after something, but not quite sure what it is! in the UK Electrical Forum area at ElectriciansForums.net
L
LukeBuckaz
Now, please bare with me while I try to explain what it is I'm after...
What I'm after is a sort of plastic collar/insert which is used when first fixing sockets and switches. They hold the socket/switch front proud of the metal knockout box so it can be plastered around. It sort of acts as protection for the wiring as the plasterer can plaster without the need to turn the power off or remove the socket/switch fronts. It also leaves a nice finish around the box so when the plaster is dry the sockets/switches can be screwed back and it all looks lovely. I think they are also used when tiling around sockets/switches.
I think that's the best way I can describe them. I have searched the forums and googled it but to no avail.
If anyone could help it would be greatly appreciated!
Thanks, Luke.
[ElectriciansForums.net] I'm after something, but not quite sure what it is!
Them just went and got one from garage.
Reply to I'm after something, but not quite sure what it is! in the UK Electrical Forum area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
