I'm not an electrician but I some clever heads together | Page 6 | on ElectriciansForums
Discuss I'm not an electrician but I some clever heads together in the UK Electrical Forum area at ElectriciansForums.net
B
beachlover
Hi everyone
I have the strangest problem that no matter who I ask in the trade they seem to scratch their head and tell me to buy a surge protection unit. I have bought a million surge protections units Just sayin
Here is the problem and some of things done over the past three years to try to resolve it ....
I seem to be getting some sort of problem that is blowing up my computers. No amount of electrical test seem to find the faults. It's not just bad components or the company's where I buy the machines either.
I have estimated Over 16 devices blown and 47 repairs since 2014. This is from five different companies where I have purchased computers with a warranty.
Computers last typically for anything up to two days or two weeks before failing. This most common failure benign burnt chips on the GPU s
It is my understanding The modern motherboards have built in surge protection and they go into protection mode when a surge is detected. I have had this happen but when I next switch on the computer the GPU is damaged or becomes damaged.
Work carried out on my electricity by the electrician working for the housing association house I live in
1 - four different surge protectors bought
2- ups bought with surge protection
3 - 2013 a full electrical test on RCD panel and all sockets - passed
4- 2015 another full electrical test - passed
5- electric supplier monitored for surges from outside- none detected
6- two sockets faceplates replaced (the ones used for my computer)
7 - independent electrician hired tested sockets. No fault found.
8 - Eco Max Home Voltage optimiser fitted on RCD panel and set to 230v
Other information.
No other devices in the house fail and we have two HD TVs, a MacBook, two iPhones, router, and the usual lamps, kitchen equipment. New mouse,keyboard,HDMI cables,USB cables purchased
UK based electrical system with RCD panel with an additional Volt regulator fitted. We have 240 volts coming into the house
The housing association also fitted a gadget that regulates the volatage 230
On the last occasion I saw the the computer component frizzle smoke and could see the damage. I'm really worried about a fire risk
I have on occasion see sparks come from the switch on the outlet.
I would appreciate your thoughts on why this is happening to me as three independent electrical test and Electricians tell me they can not find or think of what could be causing it.
No computing for me for a while
Many thanks
Not sure if I've seen a response about using a UPS to feed the computer and monitor.
It occurs to me that one possible route into the computer maybe via the DVI/HDMI lead.
Could the monitor be at fault and be feeding back down the cable to the Graphics card?
Has the DVI/HDMI cable got ferrite beads on it?
Could you try a different monitor for a while.
When the GPU card is installed is there anything close to those burnt places in the computer?
Tring to establish if all the arcing is on the GPU card or is it between the GPU card and another part of the PC?
Well ok then I'm going back to my original idea;Power quality analysis. If your PV is doing strange things then it would be picked up. I can't really see where or how you can investigate further without such an approach. I think I agree with DavisonP, turn off your PV inverter and see what happens.
I will turn off the solar panel
But to test that the solar panels are the cause of the computers blow outs I need another computer
I have to wait for the refund on the last computer to buy the next computer
It ok to test these theories if you have unlimited computers and unlimited money
I have neither ....
lol
Thank god for warranties
I'm going to run out of computer manufacturers at this rate
Just sayin
I have neither ....
lol
Just sayin
I have neither ....
lol
Just sayin
I'm done in tonight
But in the morning I will try to get some pics of my box on the wall
And the set up of my computers
Would that help
Any?
Unless the inverter has some obscure fault which escapes the inverters own protection mechanisms I very much doubt the solar PV is responsible. Will be interested to see what model of inverter is installed.
I have a UPS and used it for the computer only and plugged the monitor in the second socket on the double wall socket. Same result fried GPUs.
The modern motherboards I have had on the previous three machines have built in surge protection.
The previous one was Asus
Here
ASUS UK - https://www.asus.com/uk/Motherboards/H110M-PLUS/
And gigabyte motherboard has a failsafe too. This makes the motherboard go into protection mode if it detects a power surge. This happened in both the recent cases of the fried GPUs
Both computers techs from two different companies have told me not to use surge protection as there is no need because the motherboards are so sensitive the can detect even a slight deviation in powrr and go into protection mode
In answer to your questions. I bought new HDMI cables. I don't think they have those little lumps on them. Ferrits? I bthought they were like emi filters?
I also ran the previous computer from my tv and did not use the monitor as I wanted to rule out a problem with the monitor. The same happened running the computer through the tv. GPU failed
I don't know what you mean by anything close to the GPU
Photo of the cupboard
[ElectriciansForums.net] I'm not an electrician but I some clever heads together
The switch labelled solar PV is for the solar PV, nearby you should find an instruction label that tells you how to turn off the solar PV, there should be a local isolator switch labelled AC isolator and another one labelled DC isolator (this may be in the loft or near your inverter), switch off the AC isolator and then the DC isolator, switch off the solar PV circuit breaker.
Oh and by the way
I just remembered I bought one of these because I thought it could measure dips and surges
It was a desperate attempt to find the problem
However I don't really know how to set it up
https://www.amazon.co.uk/gp/aw/d/B0...s_1?ie=UTF8&psc=1&refRID=RG88QZX70ATZHS2YYM23
These are simple meters that can tell you how much power you are using at the current time and how much power you have used over a period of time, however it will not indicate anything, at time or provide historical data, about the state of the power supply.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
I can see the end switch says solar PV
I'm not sure about AC isolator or DC isolator. Is it that other box with the big red round thing in my pic
It is prolly best to wait until Monday when the electrician comes
Ah ok
No use then
Perhaps I will sell it
Theories they are indeed, and with or without theories or headscratching or doing nothing at all-you will still have a blown computer. So theories are not hurting or adding to your problems.
Power analysis is a way of establishing some facts. Maybe I am wrong fully accepted and I do offer this very tentatively, but at least you are out of the realm of theory and into facts. What would it hurt to try it, well apart from your bank balance. At least if you turn off the PV you should be able to find out if it is a contributive factor without power analysis.
Maybe your landlord would put something toward power quality analysis monitoring?
I think I would be looking into a Harmonics filter for single phase. The energenie power meter would in no wise give power quality analysis. A meter for this type of work costs upwards of ÂŁ1500. There are companies that specialise in this. However it is not cheap. And finally it may not be the answer. I promise I wont talk about this again.
Reply to I'm not an electrician but I some clever heads together in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
