P
pjb1
Hello fellas
Been asked by a letting agent to go and find out a problem on an imersion heater? She is telling me If they leave the immersion on for a couple of days its trips?
Couple of question for you guys
1/ To tested the immersion heater element carry out a Continuity, IR test. How do i test the stat is switching?
2/ If the element or stat is no good and I change like for like. Do i fill a minor work cert in?
3/ As there is only 2 copies of the cert in my pad do i give the master to the letting agent?
4/ What Value ohm wise would I expect to see on a continuity tested
Advise needed
Advise needed
