This is a thermal cut out which is fitted as standard in most thermostats now.
What can happen without one is that in the event of a thermostat failure the water in the tank can boil & expand to fill up the storage tank in the loft. If the tank is plastic this eventually collapses allowing the boiler water to run into the room below.
