immersion heater high limit stat probs | on ElectriciansForums
Discuss immersion heater high limit stat probs in the Australia area at ElectriciansForums.net
L
littleeley
seem to be getting a lot of problems with the high limit stats on new immersion heaters tripping out have tried several makes they all seem to have the same problem is anyone else having the problem or found an answer :angry_smile:
As Tony suggests, we have had the same problem with the sats with the integrated manual reset trip. We got the Co in and they said yep thats what they do sometimes but you can buy from us a more accurate stat that will cost slightly more.
Now I know a lot of us here will be shouting at the screen - but I want what I paid for to work properly! I know what you mean - however as a fix we are tweaking down the stat temp so the device becomes less likely to trip however you run the risk of turning it too low or the device still tripping again if not done enough. Where's the goldilocks meter when you need one.
Its easier for us to buy the more expensive stat. Speak to your wholesaler he might have a solution for you in the long term.
Reply to immersion heater high limit stat probs in the Australia area at ElectriciansForums.net
This is an RSS feed of thread: Leaking cylinder around immersion heater Content of the thread: Hi. My hot water cylinder has a small leak. It's...
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
Recommended Sponsor News
Hi everyone,
