Immersion heater on a Nest | on ElectriciansForums
Discuss Immersion heater on a Nest in the UK Electrical Forum area at ElectriciansForums.net
DaveS
London
Hi all
Have had a request from customer that would like their immersion heater controlled via a Nest. It has standard 2 elements and is not on Economy 7. My initial suggestion was to just put in on a Horstmann timer but he is adamant would like it on Nest, has bought the bits already including relays. My thoughts we're that this would require 2 nests to control both elements individually and would become convoluted and impractical. In all honesty he seems to have quite a bit of electrical knowledge......maybe a bit more than me in regards relays and nests. He has previously set up a standard electrical heater in similar fashion with a relay. He sent me the attached drawing of how he proposes the Nest to be wired, my question is, is this feasible and are there any glaring errors that would make this impractical to be used with a Nest and immersion with 2 elements?
Many thanks for any clarification on this
  • [ElectriciansForums.net] Immersion heater on a Nest
Heating element 2 appears to have a switched neutral which is a no no, and I would use contactors rather than relays. Definitely ditch the 5v supply... the Nest should be capable of switching 230v (3A max which should be ample for a coil or two).
They are 40A solid state relays which will be more than capable for this task (and silent!). I agree it would have been simpler to use solid state relays with 240V input to save on the need for a transformer.
Where are the thermostats for the elements? Nest in this application is simply acting as one big remote switch
I know and I agree with the reasoning in general (their silence), just personal preference (mainly due to double pole switching and less chance of an explosive finish if a contactor fails).
Reply to Immersion heater on a Nest in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
This is an RSS feed of thread: Two electrical supplies and a single immersion element Content of the thread: Good afternoon, new joiner here with...
