hi.
i went to see an immersion heater tonight that hasn't been working for a number of years according to owner.
soon as i turned it on it trips the rcd, then i take off connections at immersion heater and it doesn't trip rcd. so tells me the element.
when i took element cover off you could see a white coating all around which i think is limescale/corrision(hard water area). when IR test i got short between all conductors.
would corrosion in element cause short between conductors?
when measured resistance of element the reading was 18.3 ohms. which i think is an ok reading.
any views welcome .
any views welcome .
