cprfenom
- Joined
- May 28, 2011
- Messages
- 389
- Reaction score
- 116
I went to a job that the owner felt was a bodged job. It was basically a radial circuit wired at the start in 4.0mm T&E, and then it goes to a few sockets that is supplying a washing machine and tumble drier. From there it goes upstairs to the airing cupboard where it feeds a single switched socket that the owner has to swap either the immersion or his shower pump, and then the circuit goes up to the loft where it feeds the boiler. All the wiring apart from the first leg of the radial is 2.5 T&E and fed from a 16amp MCB 60898
I was always under the impression that from the 60's immersions were on dedicated circuits and in most cases fed off of a DP isolator.
I rang Napit and they have said that although its bad design its doesn't breach any regs and that in an EICR it could only be coded a 3 as it is on a radial and not a RFC.
This doesn't sit well with me as it goes against everything I have been taught and told to date.
Opinions please
Opinions please
