Immersion tripping RCD | Page 2 | on ElectriciansForums
Discuss Immersion tripping RCD in the UK Electrical Forum area at ElectriciansForums.net
HIi guys,
Had a call out to a property today and looking for a bit of advice. As stated the RCD trips whenever the immersion heater kicks in.
I have disconnected the incoming cables and Insulation Resistance tested them and they come out >200MOhms which is all good.
The element is a Theeta WT7 and the RCD trips whenever this reaches set temperature.
When i disconnect the earth from the immersion it holds and when I link through the element it holds. It's only when I introduce an earth that the RCD trips.
Am I missing something really obvious? Or is there something I've failed to do? I hoped it'd just be the element but the problem occurs when it's been linked through which is bugging me.
I want to be able to say I've taken it as far as possible until the plumber is back from faking sickness!!
I've tried to attach some pics of the issue.
  • [ElectriciansForums.net] Immersion tripping RCD
I feel like a complete doughnut. I googled Theeta W7 and the first thing that came up was "heating element". I wrongly assumed it was some sort of element and stat in one.
Numpty :banghead:
As an aside... I had an element that kept tripping after a board change - RCBO board for an old 3086 job. Scratched my head and tested everything. Cable, element etc all OK. It was only after the circuit was in pieces that I realised that I had fitted a 6A RCBO rather than a 16A. What a donut!
easily done. some of these MCBs you need a microscope to read the values. same with sockets and switches. and as for trying to read those stupid timer and lux symbols on security PIR lights, with the sun in your face, forget it.
Reply to Immersion tripping RCD in the UK Electrical Forum area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
Recommended Sponsor News
Hi everyone,
