Immersun type device for 6kw immersion? | on ElectriciansForums
Discuss Immersun type device for 6kw immersion? in the Green Lounge (Access Only) area at ElectriciansForums.net
J
jerriais
For a sports pavilion with an 8kw PV array. Anyone know of an Immersun or equivalent that can be used on a 6kw immersion. So far max I've seen is for 3kw. Thanks!
You can easily dasiy chain two Immersuns to do it - they are actually designed that way, using a single CT clamp... They'll do it straight of the box :) Just configure them when you fire them up :)
Aha - is it a single 6kw?
You could always put in a three phase 9kW immersion (it's three 3kW immersions in one unit) and then use the facility above.
Reply to Immersun type device for 6kw immersion? in the Green Lounge (Access Only) area at ElectriciansForums.net
    • Friendly
This is an RSS feed of thread: Leaking cylinder around immersion heater Content of the thread: Hi. My hot water cylinder has a small leak. It's...
You can use timers to turn ON/OFF circuits during the day to maximize your self-use of solar power. Turn ON low draw circuits such as a 1Kw pool...
