Implementing a system based in Android + IOIO + relay problem + connector | Page 3 | on ElectriciansForums
Discuss Implementing a system based in Android + IOIO + relay problem + connector in the UK Electrical Forum area at ElectriciansForums.net
A
annlee
Hi there, I am doing a system based on Android + IOIO board + Relay for a 230V/16A connector (I am European)
IOIO board only gives 3.3V output (not 5V), so I need a 3.3V relay that works for a 230V/16A connector, is there any relay with this specs?
or
should I need a MOSFET transistor between the IOIO board and the relay? which one?
Thanks in advance
Ah, you do not appear to be burying it but putting it in an accessible underground chamber. That makes a difference to the cooling aspects and the accessibility for maintenance. The recommendations from others about using under rated components to minimise heat will probably still be valid. Will you get a reliable signal to activate the phone without an external aerial?
We need to test several covers and study which materials have in average better: hardness-heat insulation-signal allowance, however its too early stage to know that yet
are there any questions that you have or would you like some help with your hardware design?
Thanks you are very kind,
I have a lot but if you dont mind I will rescue this thread when I receive the hardware and start working on it
Examples: I plan to add a typical green/red LED to show if its working or not, plus a proximity sensor to start the App
Please mods don't close this thread
Reply to Implementing a system based in Android + IOIO + relay problem + connector in the UK Electrical Forum area at ElectriciansForums.net
I have an AC system that is not working. All fuses and relays tested successfully. Blower comes on, but blows hot. System is completely empty...
