The sooner there are classifications and registration of electricians the better.
Being purely industrial all my working life I’ve not really got involved in domestic, which as you may notice I try to steer clear of. Over the years I’ve only come across one domestic electrician successfully migrate to my side of the industry.
You say being an electrician isn’t brain surgery, maybe its not, some of it is very complex and diverse though. You go to work and it’s not a rewire at No. 7 Acacia Avenue which is just the same as No. 9 Acacia Avenue that you did last week.
You go in to work with a rough idea of what you’re supposed to be doing, not very often it turns out that way. We did try to plan work, it’s amazing how quick proactive becomes reactive as the plant falls apart.
Interviewing candidates for a position the first two things I would ask is can I see your indentures and what experience do you have? Not an unfair thing to ask when letting someone loose on dangerous and very expensive kit. Kit that if broken down is clocking up losses at the rate of £10,000’s per minute.
So if you’re happy to be a domestic installer, that’s up to you. But what happens if you’re asked to work outside your comfort zone? There’s no point going on a forum, no one will have a clue what you’re talking about.
I’ll quote E54 “you can’t defend the indefensible”.
