in line fan for 2 ensuite bathrooms | Page 2 | on ElectriciansForums
Discuss in line fan for 2 ensuite bathrooms in the UK Electrical Forum area at ElectriciansForums.net
F
foghorn
hi and thanks
could some one give me a heads up on how to wire x1 inline fan with timer to activate with 2 bathrooms ie either switch will turn fan on switches located outside of the bathroom and fan has a triple pole isolator
I prefer to read 'BS671 is non-statutory' and treat it as a guide to minimum standards regardless!
and if something goes wrong the the big green book will hit you hard ,not easy to explain to a judge ,and regarding fuses in fans, they are required if a fan seizes a 3 amp fuse will blow before a 6 amp mcb will trip ÂŁ135,000 worth of damage to a shop in Manchester caused by a seized fan also a hair salons toilet fan seized motor dropped out of the fan and set fire tpo the shop , 2 people died in a hotel fire cause by a seized fan and thats the reason for fusing down fans and that is where common sense comes in
Reply to in line fan for 2 ensuite bathrooms in the UK Electrical Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
