In line fuse holder | Page 2 | on ElectriciansForums
Discuss In line fuse holder in the UK Electrical Forum area at ElectriciansForums.net
mhar
devon
Got some coastal apartments which have a mixture of downlights, pendants and 5A round pin wall plugs all controlled by conventional light switches and everything is switch fed. OCPD is a B10 mcb which if I derated it to a B6, would still be over the 5A rating of the sockets and plugs. All the 5A rated plugs used are unfused.
I am looking for small inline fuseholders for 3A 1362 fuses (or anything else suitable) which I can fit in the switch backboxes. Otherwise I will have to come out of the cu from the 10A mcb to an sfcu fused at 5A which, whilst easier, doesn't feel right. Or am I missing something?
Which is partly my concern. The manufacturers are supplying a light complete with a 3A fuse to protect their device and cable, we then discard this and connect into a 10A supply.
Thanks for the replies
Dumb question, sorry, but are you saying the light had a manufacturers 3A fuse which has now been removed ?
Yes. BS1362 plug which has to be removed to put on the unfused 5A plug. Therefore quite likely a .5mm cable being protected by a 10A ocpd
Are you missing something, do you seriously believe the cable is going to be subject to overcurrent conditions.
Hi Westie - Overload current agreed no prob. But perhaps manufacturer's cable not sized to trip mcb under all fault currents, which may be why they put 3A fuse ?
Using the adiabatic eqn and Wylex i2t data sheet for their 10A B type I get 0.5mm is good for about 1200A of fault current. This calc has a 12:12 warranty - 12minutes or 12reads :)
Yes is possible but the manufacturer has to fit a plug and for this country it is going to be a 13A plug. OP you could try the 5A plug from MK part no. 643WHI which comes with a 5A fuse but you could probably change it for a 3A. I would guess it is a BS646 fuse.
Now I like that - not seen them before. There's your answer then OP.
Daz
Reply to In line fuse holder in the UK Electrical Forum area at ElectriciansForums.net
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
