in-line fuses in fan isolator | Page 2 | on ElectriciansForums
Discuss in-line fuses in fan isolator in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just checked Vortice Punto fans online Vortice - A Breath Of Fresh Air For Tomorrow's World . The instruction booklet doesn't mention 3amp fusing, just a multi polar switch, so they should be perfect.
Hope that helps, good luck bud.
Steve
cheers ill check them out. never heard of them but so many exist. might end up silavent route yet depending on whats local as pushed for time but will consider these in future too. all the best
I'm pretty sure that silavent will require 3amp fusing as well. My local Denmans stock Vortice, so it might be worth trying yours, if you've got one.
Reply to in-line fuses in fan isolator in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks very much, also a good tip :)
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
