sparky692
Hiya Fellas. Need some views on a up and coming job
quick scenario.. 3 phase 100amp head and supply . 9 units all slightly different but all with the same head and supply.
some have 16 or 25mm tails through a isolator to either 3 phase DBs or that plus a single phase CCU.
question is as far as the single phase ccu is concerned i think i need a 60 amp switch fuse between the head and the main switch on the ccu as its only 60/80 amp rated. also size of the tails should be 25mm minimum as its 100 amp head. Any views . switch fuse with 25mm tails or is it ok ?
