So the plasterers are getting on with their job of prepping the walls and are nearly done removing the old plaster - had to go back to the brick in some rooms or to just studwork as the lath and plaster was just crumbling away.
Now it will be the electricians turn to remove all the old wiring and rewire the new sockets and lights - which will be made easier as the house is bare.
Now after he has put in the sockets (but not the fronts and wired up the new CU - does he then go away and the plasters come back to board up and do the skim plaster - is this known as the first fix? The electrician then returns to attach the socket fronts and have everything connected up - the second fix?
