I like that. I'm sure If EMT was available here we would use conduit more. The screwed steel we have here is a bit 'heavy duty' for regular use. I did install some more 25 and 32mm galv today, yes I measured out all the bends.
Sounds like a business opportunity there, unfortunately in this rush rush world it would certainly slow the job down and would end up like all good ideas.I tend to agree , if we had a lighter gauge steel conduit which could be easily bent with a hand bender and Used grub screw couplers (No more threading) then way more jobs would be done in conduit
i would certainly try to use it where possible, but as you say it will still be slower than throwing in T&e.Sounds like a business opportunity there, unfortunately in this rush rush world it would certainly slow the job down and would end up like all good ideas.
ear, metatarsals, throat?Americans use EMT
Don't want to go off topic here but I think that pc1966 has hit on what should be a very, very significant thread "how often has FIXED WIRING caused fires"?That is a nice looking building going up!
I can kind of see the point, EMT is pretty flame containing and it makes inspection easy (EMT yes/no?, not Hmm, is this cable of one of the approved types for this circuit?) but it also looks like a bit of a power-grab by the union, and other cables are quite safe when used appropriately. Still, hopefully least to higher standards than often seen in new builds.
The other think is how often is it fixed wiring that is at fault? I would expect it is the appliances and their flex that cause most fires.
Also another odd difference that I heard from @Megawatt is that USA generally has its GFCI/AFCI at the outlets, where as in the UK/Europe it is normal to have them at the breaker board so they protect the fixed wiring from faults (or limit the risk to DIYers drilling walls for a new shelf) as well as attached equipment.
Yes the pvc pipe will protect from trowels etc but also from chemical damage caused by anything acidic in plaster/cement etc.In domestic situations I've only seen PVC conduit used. Others will be better placed to explain why it is used in every installation, but I always thought the basics were to protect the cable from trowels and also make future repairs or additions more straightforward.
My experience is minimal, but I've replaced cables by pulling through 30 or 40 year old oval conduit and was extremely grateful for it being there.
