O
Osborn
Hello all. Never seen a cable service head like the one in the flat I've just moved into (AEI - from the 1960s?). It's 3 phase (60amp fuses), but only feeds two flats (mine and the guy downstairs). Have cleaned the filthy contacts on the live cable head fuse for my flat, and also cleaned contacts in the meter, and in the isolator switch it leads to (MEM and even older than the cable head, by the look of it)... Yes I know I should be getting EDF (supply co.) to do all this, and I could be fined a grand for breaking their seals, but the chances of either of those things happening are - erm - remote. Question is this. I want to upgrade the input and output 16mm meter tails to 25mm. Pulling the live fuse in the cable head - no problem - already done it several times - but are there issues with disconnecting and replacing the existing cable to the common neutral in the cable head? Would only be disconnecting/reconnecting the neutral for my flat at the cablehead common neutral - I'm not touching any of the wiring for the downstairs flat. All wisdom welcome. Many thanks from a newbie…
