Increasing 3PH Supply? | on ElectriciansForums
Discuss Increasing 3PH Supply? in the UK Electrical Forum area at ElectriciansForums.net
-Matt
England
A company i do work for are running over the capacity of their existing 100A 3PH supply, they are pulling around 100-120A all day long.
I am trying to get them to get a bigger supply, they have tried asking for a 250A supply from the DNO, but they want ÂŁ20K. (they reckon the transformer would need upgrading)
Its an overhead supply, and a transformer (pole mounted) is only 15-20 metres away, on boundary of customer property.
I don't know what size the transformer is, but its not the smallest I've ever seen, and only looks to supply 2 properties.
Ive just had the thought of a second 100A supply, as it would be dead easy to split the demand across two supplies.
Has anyone tried getting an additional 3PH supply? and was it more cost effective than a 250A supply?
I guess it still comes down to if the transformer has capacity, but i find it hard to believe it would be maxed out with 2 properties?
Cheers
Cheers
Is the 120Amp just limited to 1 phase or are all 3 phases affected in the same way?
Have you asked them what size supply it would be possible to get without an upgrade of the transformer?
Is there a planned increase in the current load, as you’ve requested a supply just over twice the current demand I assume there must be?
They almost certainly won’t give you a second supply in to the same installation, especially not such small supplies.
A cost effective option may be to request an additional 100A single phase supply and separate some/all of the SP loads off the TP board, to bring its load down under 100A. Assuming the DNO will allow you the additional SP supply, of course.
Prompted by davesparks good idea of a load study, could you tell us please what major equipments are responsible for the lion's share of the load current and whether they are on all the time or scheduled? I am wondering whether the client might be interested in an energy audit to see if he can achieve the same business outputs using less energy (load current) either by changing the way the equipments are used or controlled or by investing in new equipments or sub-systems of them. After all 415 x 1.73 x 120 = 86kW so 86 x 8 hr working day = 688kWh or 86 x 24hr(all day long) = 2064kWh.
688 x 13p/kWh costs ÂŁ90 a day(ÂŁ33k) and 2064kWh costs ÂŁ270 a day(ÂŁ99k). (Figures in brackets over 365 days)
If say 10% could be saved in energy that's ÂŁ3k a year or ÂŁ10k a year reduction in cost for 8hr or 24 hr usage respectively
Updating air compressors, process heating, HVAC, refrigeration plant and lighting (or their control) are candidates for 'spend to save'. I have no experience of the magnitude of typical savings but 10% does not seem unrealistic to me.
Just some thoughts to go in the melting pot on a different approach to spending ÂŁ20k and achieve the same end.
In my experience the DNO will not put 2 seperate supplies into same buildng, especially a small one.
Why not upgrade to 150/160A amp this may be surprisingly affordable compared to the 20k 250A supply
I have been managing a 80amp TP supply, as the DNO want ÂŁ55K to upgrade !!!.
The ideas already suggested have worked so far, these are.
1. LED lighting throughout, thats low bays, security and office.
2. PFC (didn't offer much, but i know some other installations can benefit substantially, so worth a visit.
3. Gas supply was easy to upgrade so all electric hot water and electric heating was removed, new combi installed to supply hot water throughout.
4. 3 X ammeters installed so manager can keep an eye on it and manage machines in sequence so to smooth out peaks.
5. Most machines have VSD which has a huge impact on start currents.
So far, clients supply hovers around 80 but now rarely goes over, often it is much less.
Hope this helps
Reply to Increasing 3PH Supply? in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
Hi Mainline and thanks for the reply. My inverter is only fed from the mains supply over a 4 hour period at night and it does not have any tie...
