I am installing an induction hob to a dedicated 32a supply. The hob is rated at 20a. From the hob I am going to use a heat resistant butyl 3 core cable. The 2.5mm cable is rated at 24a, this seems a bit light to me, do you think I should use 4mm which is rated at 35a or will the 2.5mm be ok, Thanks in advance
