Induction hob connection and switch | on ElectriciansForums
Discuss Induction hob connection and switch in the DIY Electrical Advice area at ElectriciansForums.net
verar
Manchester
My kitchen was rewired last year and I had the electrician run a cooker circuit "just in case" as I was using a gas cooker. He terminated it in a double socket. Now I'm redoing my kitchen and would like to fit an induction hob (7.4 kW) and a single electric oven below (2-3 kW).
The double socket is not appropriate anymore as the hob will be hardwired and most likely the oven too. I'd like individual switches above the worktop for each appliance, is this possible? I haven't seen double cooker switches on sale, except including a socket which I don't need at all as I've got plenty in place already.
Does the cooker switch rating matter? If it's 45 A and the fuse at consumer unit is 'only' 32A, it's the latter which will trip first? Most cooker switches are 45 A rated. I'm attaching a pic of the consumer unit - it says B32, does that mean the fuse is 32 A?
For the oven, I could run a 13 A FCU from a dual outlet plate or even a socket straight from it?
[ElectriciansForums.net] Induction hob connection and switch
Hi - the cooker switch rating is to ensure it's sufficiently engineered to carry the load. It will never trip due to a fault. It's just a manual isolator and 45A rated ones are common. The MCB and RCD in your consumer unit may trip in response to fault conditions.
i can sort that out for you, unless there are members closer.
Reply to Induction hob connection and switch in the DIY Electrical Advice area at ElectriciansForums.net
allowing for diversity a 32 amp supply will be fine for them both, but remember, the cable needs to be adequate to cope with a load on up to that...
Thanks for the swift response.
