Hello Forum,
I need to replace the hob in the kitchen as it is faulty.
I would like to be able to use an induction hob, so I need to make sure that the wiring and mcb on the cooker circuit is the right specification.
The combination Oven (1 small / 1 Large ) has a Max load of 4.1Kw.
The induction Hob has a Max load of 7.35Kw.
So that is a total of 11.45Kw.
The cooker circuit is on a 32a mcb.
The wiring is all 6mm T&E, a single cable goes from consumer unit to isolation switch, then splits into two 6mm cable, one to the oven, one to the hob.
It is a new build with all wiring hidden behind plasterboard walls and plasterboard ceiling.
From what I read, it appears that the 32a mcb and the 6mm cable is of adequate specification.
Obviously I want to make sure all is safe, so could you confirm this or advise what needs to be upgraded?
Thanks in advance
Richard
Thanks in advance
Richard
