Induction issue | on ElectriciansForums
Discuss Induction issue in the Electrical Appliances Forum area at ElectriciansForums.net
the pict
Mentor
Brodick
Beko BVD1668K, Rear hobs work Front ones not , I get the symbol to put on a pot any ideas, what actually is the sensor , what does it look like and is it worth the repair
Dev
I wonder if you have lost power to half the hob, check power inlet for damaged terminals
Would the panel lights still work tho, but I never had the cooker so out perhaps your rightif the terminal block has a split connection affair
They may well work.
I can imagine control voltage coming from L1 terminal
May well use a ct coil to detect current on supply to each ring, therefore if it thinks there is power to ring and the current is not being measured, it may see that as pot missing
Reply to Induction issue in the Electrical Appliances Forum area at ElectriciansForums.net
In all likelehood, no different. The RCD on the left is looking for electricity that is going missing in action. If the total missing reached...
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
