Industrial Boiler Installation | Page 2 | on ElectriciansForums
Discuss Industrial Boiler Installation in the UK Electrical Forum area at ElectriciansForums.net
dazzlaaaaaa
hi everyone
first post, so please be gentle :)
Hoping someone can help me out. I have not been involved in very much installation work over the years as my job is more maintenance orientated. Work is currently installing a new industrial boiler and i am trying to work out cables schedules and fusing from distribution board to boiler panel. The boilers normal full load characteristics are 415v 34 amp full load. But the start up current is 134 amps approx. The main rise in start up current is caused by a force draft fan motor, wired in star/delta and a water feed pump. What i am pondering over is should I be sizing the cable and fuses accordingly to allow for start up current as I don't have any information on start up times and how long this start up current will be present for also these motors will be stopping and starting numerous times throughout the day.
Obviously dependent on whether i should be sizing for start up current will greatly affect size of cable I need to install.
Thanks everybody in advance
Hope someone can point me in the right direction
assuming a flc of 34A per phase, 6mm or 10mm, depending on derating factors and VD. the start-up current of 134A is for a very short duration and should be handled by either of those 2 conductor sizes. obviously type II or type III fuses will be required .
I believe that full load is 34a per phase not across all phases. I am definitely unable to use cb unfortunately as i know this would be ideal for inrush current, i am required to fuse the circuit within the old db that fed the removed boiler
Reply to Industrial Boiler Installation in the UK Electrical Forum area at ElectriciansForums.net
Issues With Nest Generation 3 Operating Boiler? I have a Google Nest Generation 3 Thermostat/Heatlink, Thermostat is in the hallway and operates...
Dulbert
Sorry for the late reply I found it very difficult to find work but I’m not sure if this was down to Covid and all the lock downs happening just...
