Leesparkykent
Nearly Esteemed
Back to the OP... your probably using diode bases. Have a read of this especially page 6 http://www.gcg-es.com/Principals Pr...ley AIS 02 - Fire Detection Systems Guide.pdf
Discuss INDUSTRIAL FIRE ALARM in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
ah you legend axactly what i was looking for cheersBack to the OP... your probably using diode bases. Have a read of this especially page 6 http://www.gcg-es.com/Principals Products/8 - Morley-AIS/Morley AIS 02 - Fire Detection Systems Guide.pdf
excellent thankyou .basically, the diode in the detector base is there to preserve the loop continuity if the head is removed, so that although the system is in "fault", the rest of the loop detectors can still signal the panel to activate "fire".
HI AGAIN ALL
INSTALLING INDUSTRIAL FIRE ALARM FOR FIRST TIME. FOLLOWING INSTRUCTIONS BY MATE.
CAN SOMEONE EXPLAIN HOW THEY WORK ?
I THOUGH THEY HAD AN EOL RESISTOR TO GIVE A FIXED RESISTANCE VALUE THAT THE PANEL WOULD MONITOR. BUT WHEN INSTALLING HEAT DETECTORS EACH HEAD SEEMS TO HAVE A RESISTER IN IT.
IS THIS CORRECT ? WHY IS IT THERE ?
TIA
Reply to INDUSTRIAL FIRE ALARM in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
