R
Robo
A friend of mine has a 3phase roller door. Under normal circumstances you press the up button and it opens and continues to go up untill the limiter switch kicks in. When it comes down you have to press and hold the down button. I guess this is for safety reasons.
The up button has stopped working but the down button works fine. If you remove the cover and press the contactor buttons you can press and hold it and the door opens and likewise going down. However the up button and down buttons seem to work back to front.(the contactor which i assumed would open actually closes and vice versa.
I went upto the motor and looked at the limiter switch. I tested continuity through the switch to see if it worked and it did.
I have no experience with these doors tbh and im a little baffled and hate being beaten
Does any1 have a simple guide to help me understand the problem and to identfy a faulty part.
Thanks Robo
Thanks Robo
