Inexplicable chain of events | Page 2 | on ElectriciansForums
Discuss Inexplicable chain of events in the UK Electrical Forum area at ElectriciansForums.net
Dave 85
Ive just been subjected to the most inexplicable chain of seemingly unrelated faults of my career and wondered if anyone might be able to shed any light.
So here goes...
About 18 months ago I did quite a bit of work in a house, new kitchen batroom, utility, consumer unit etc.
The board I used was admittedly a cheap one. The make was Tradeline, 16 way RCBO board, about ÂŁ150. I naievly assumed anything being sold in a decent UK electrical wholesaler would be fit for purpose, and the boards had been recommended to me by more than one person.
The first thing I noticed after I installed it was that one RCBO was still on when switched off (bad omen) so I replaced this and no more probs. All circuits tested out fine, nothing less than 5M ohms IR. The client hadn't had any issues until a couple of weeks ago. I got a call saying 'our deep fat fryer has packed up, its been fixed but now the RCBO won't switch on. I went round tested the circuit and the fryer and replaced the RCBO (individual 16 amp circuit) All worked fine.
A week later I get a call saying that there was a burning smell coming from the C/U so I sais switch everything off and went straight round. Client was out when I got there, I checked every single screw was tight, found a couple slightly loose in a henley block, fired everything up and couldnt see any probs. A few days later more burning smell 2 different circuits trip out then the whole house has gone dead. Went straight back round at 9pm and the main switch is stuck on with neutral continuity completely gone, so that explains the burning smell. Put a new main switch in but now kitchen ring RCBO wont switch on. Tested circuit and it showed about 4 Meg ohms IR. Temporarily put the kitchen ring on with the upstairs ring. All worked for a few more days then the kitchen/upstairs ring starts tripping 1 or 2 times a day, sometimes at night so overload seems unlikely.
Ive put a new RCBO in for the kitchen ring tonight, contactum one this time because I refuse to use anymore of that tradeline crap.
Circuit still shows 4 m ohms IR checked behind every socket but this reading is coming off the leg from the CU to thge first socket (one of only two legs of said ring that I didn't install.
Working so far.
Another thing...in the last week the clients wine cooler and a radio both on the kitchen ring have packed up. They are very decent people and are not blaming me for this or seeking any compensation but it doesn't look good.
The house could potentially be drawing over 100 amps at times as they have a 7kw electric back up boiler which is only used during the winter and has not been used since well before all the trouble started.
To me it is hard to link any of these events together yet they have all happened in the space of a month after well over a year trouble free.
The only thing I can think of is that the dodgy main switch has put a lot of heat back down the neutral bars and cooked some of the cheapo breakers.
Needless to say it is the first and last time Ill ever be buying any Tradeline stuff.
Anyone got any ideas as to whats going on here? Any input would be much appreciated.
It might be worth approaching the customer and trying to make an arrangement with them. If you explain that the board with it's chequered past is not up to your personal standards of reliability and even though it's out of warranty you'd like to replace it....... apart from the cost. Maybe suggest they chip in the price difference between the cheap board and a good board or even possibly 50% of the cost price of a new board and you'll foot the remaining cost and the labour. The customer did save money on the original install by having a cheap board installed so if they're decent they may be happy to pay in something to prevent future problems.
The guys absolutely loaded. Im sure the only reason hes not offering to pay me to redo it all now is out of politeness. Problem is, Im working 50-60 hours a week at the mo just trying to keep on top of my current work so haven't really got time.
Good idea though, I'll probably come to some sort of arrangement like this with him when I get the chance
Tha nere got rich by bein generous lad. I’m a Derbyshire lad.
He wanted the cheap board fitted so charge as appropriate to change it. Being a nice chap doesn’t come into it.
Reply to Inexplicable chain of events in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
Yup will do exactly that when I'm back down there. Thanks for the help
