I am currently at school in year three of the 2330 and have just taken the 302 and 303 (I think) sections which I am confident about. Next steps will be the 17th Edition and the Inspection and Testing exam (obviously whilst still continuing with the 2330). I am intending to register (probably with ELECSA due to price) in the next 3 months or so.
Anyway, went round to a house recently to advise on aerial work for a new extension they were proposing. When I turned up two block walls had been removed and half a dozen sockets c/w metal backboxes were just left dangling and live in the kitchen / dining room. They have a four year old child who is into everything so used a few words not allowable on this forum and explained that they should be made safe ASAP. Anyway, got my first job which was nice and easy, breaking the ring in the middle, extending this middle section and reincorporating it into the ring plus alterations to the lighting circuit and a small extension. I fully explained my situation to the customer and that I wouldn't be able to sign the job off until 1st/2nd quarter of 2012, that we were actually reducing the loads on the circuits (replacing appliances with energy efficient ones, LED lighting etc), is that ok by them, yes fine! LABC informed of the work.
Needless to say it didn't go according to plan. Kitchen fitters arive and cooker point is in wrong place, new one is 17.4kw. Even though diversity calcs said 6mm and 32A mcb it felt wrong so said I would be far happier with 10mm cable so now having to touch another circuit (not in the slightest bit concerned competence wise apart from the certification point of view). Put in new feed and do Zs to get a reading of 89 ohms, new meter so a bit unsure of my result, ir test fine so do a Ze and still 'bad' result. Unable to find meters or where supply comes in so I look at nearest pole and the area has pme. Speak to son (Western Power linesman) who says it is almost bound to be pme. Customer returns home, we find meter cab under piles of rubble, no earth tail coming out of cut out. Get home, speak to son who comes out with me to take the **** but agrees it is tt (the tt system that school says we will very rarely encounter) so obviously some other considerations to take into account but I am still ok with my competence level.
Next thing is the rcd starts tripping a lot. It has been an ongoing problem for the five years that the customer has owned the (15 year old) house so I am told but never this bad. Completely random and just as likely when the house is unoccupied and 'nothing' on. So, central heating, fridges and freezers the main suspects. Ir test everything and all fine but do notice a few nasties like a 240v socket next to a basin, 240v fan above a bath etc and am beginning to get a bit concerned about rectifying such things without yet being able to certificate. Meanwhile customer agrees that a conversion to pme is a good idea so I have now decided that this work needs certification upon completion (rather than wait until I am able) and approach a local electrician, explain the situation and he agrees to help out - there were a few other minor complicating factors as well but I won't detail them here.
The result is that the electrician visited last week, is completely happy with what I have done, agrees with my thoughts and proposals, is happy to help / supervise the job and sign it off, even though he says that I am quite capable of doing the work and am possibly worrying too much!
So, the question is, should or can I put this job forward for my first assessment even though it will already have been signed off by someone else? The implication from getting help is that I am not competent but that is not the reason for seeking help but, admittedly, it is reassuring to have my thought processes and proposals agreed with. My thoughts are that if I get the 'wrong' assessor then he could view this negatively yet I feel that I have done the safe and correct thing
