F
FIGLE
Hi,
I'm considering including an inline dimmer switch for a tabletop 'mood' lamp (mains connected) I'm currently prototyping. The lampshade is made of paper glued to a clear flame retardant PVC which is also the structure of the lamp (like an origami). I'd like to use low energy 4-6W dimmable LED bulb inside to keep everything cool.
So far I have only found two electronic dimmer switches by Relco (here and here) for LEDs and they are quite expensive. Given the rapid spread of LED technology I find it surprising if not disappointing. Am I asking too much? Should I rethink my design to use either incandescent or custom circuit with low voltage LEDs and AC power supply?
Thank you!
Thank you!
